Ok heres one;
I have owned my Scenic for 2 years now and only the second owner and its only done 32,000 miles but the funny thing is when you let out the clutch it makes a quick hmm noise and goes away.
What causes this:confused:
And thanks in advance
Sounds like the clutch thrust bearing starting to wear - Does it make the hum when you depress the clutch when stationary and dissappear when the clutch is released ?
I Agree With 53 Scenic, I've Had Mine 4 Years And It's Always Done It, I'll Change It When The Clutch Needs Replacing, But Until Then It's Not Worth Worrying About.
Thanks what i thought but being and Alfa man we dont silly noises like this :moonie: :moonie:
It only happen when you take up movement but I will just turn up the radio abit:d
Cheers
