2004 Scenic 1.9dci Dynamique
I am being driven mad by a creaking coming from just above my right ear when driving. I have traced it to the grey headlining just before it meets the black door seal. This creaks terribly when driving. I can replicate the noise by pressing and squeezing the headlining.
Now that I know the source of the problem can anyone advise me of a solution to it?
Otto, do you know if the door seal just pulls off or is it glued in place?
Have tried giving it a wee pull but it seems stuck solid in place?
I thought it just pulled off ? but I have never tried to remove one.
Try a post under Scenic seal removal maybe get a bite from a Member.
Ottoman
Hi Scenicman - have a look round the door seal until you find the joint and see if it will pull off at that point - they can be stiff to remove and hard to refit - the guys in my local garage use a small rubber hammer to reseat them properly. Befor eremoving the seal completely mark it with chalk or a pen to ensure it is refitted in the same position.:)
Have you managed to sort out the creaking Scenicman?:)
