hi, don't know if this is a common problem. the bodywork around the bottom door hinge , driver's door, has fractured. passenger door side flexes when opening the door, seem very weak. car is renault scenicRX4.
Re: door pillar problem
Sounds very much like the hinges have seized. Ideally you'll need to drive the hinge pins out for a clean-up. And then try and get the fractures welded.
