took my x reg scenic to the garage they told me the speedo head is faulty,there is a pulse up to the clocks.so i went to a breakers and tried 6 sets of clocks but still no good. has anyone got any ideas. thanks
Check with the renault garage but the new speedo head may need reprogramming as the pulses recorded are also used to store mileage, etc:)
Are you saying that you have tried 6 different second hand speedo heads and none of them have worked?.If thats the case,then there can't be a signal from the speedo sensor as the chances of having 7 faulty speedo heads is pretty much impossible!.
Where did you have it diagnosed to(Dealer or Independant?).
