can anyone tell me where is the fuse box for the sun roof in a rhd renault scenic dynamic 1.4 year 2004. I have located the fuse box for ignition, lights, etc. Renault manual states that the fuse box for sun roof is under the hand brake handle as you guessed its not there any ideas or maps. Thanks Wack.
Hello & Welcome to the Forums,
Have you located the fuses in the glove compartment & the ones lower right off the steering wheel.
Where the Manual indicates the fuse to be is the location off the Renault Clips diagnostic socket if you raise the mat/plastic cover, I am not sure where the location off the sunroof fuse is located as I do not have a sunroof fitted to my Scenic II .
Ottoman
