hi can anyone help, i have a W reg 1.6 sport scenic, every time i turn (both ways), hit a bump or even put the brakes on theres a knock from the front end. has anyone had this problem before and is it easy to fix.
cheers
I would check the bushes at either end of the anti-roll bar, probably worn and in need of replacement. Mine actually had a broken retaining clamp which holds the anti roll bar bush. Cheap enough and easy to replace
