Nothing reading on any of the injectors
Try this step first
Connect scanner, get someone to crank while you spray easy start into the inlet manifold , MAKE sure you are standing at the side of the van keep spraying while they crank, see if you can get it to run for around 30 seconds with Easystart
Should be able to use airfilter housing to spray through ( Pipe that goes to turbo mouth )
Use the primer bulb if fitted to get fuel back up to the pump
Just tell them dont turn Ignition OFF should it run , if it cuts out dont try and restart
as in IGNORE it stalling , DONT AT ANY TIME switch ignition off, IF you do Repeat above
Now read codes, see if it now shows what if any injector circuit is open
IGNITION switched off Injector you are after will be lost from ECU
No Keep alive In Memory on cars now to talk about ( Or you can trust )
IF no joy, Try the Method Below
Unplug the injectors
ALL 4, now crank and scan.
Anything showing on fuel rail pressure now
Then put 1 injector lead on at a time
So each injector is scanned 1 at a time If you see a dodgy reading on 1 . leave that one off
Then
put plug back on 1 injector then plugs on 2 injectors , then plugs on 3 injectors then the dodgy injector last,
See if you can narrow down which one is playing up
Be careful, Dont be surprised if it fires up and runs on the 3 good ones and not with the dodgy 1 SO DONT STAND IN FRONT
No real test procedure for this fault code
As its change all 4 injectors
But come across this fault type before on the Citroen/Peugeot range, and it is only 1 injector thats gone, its just finding that injector
AND these bags of sh1te below
The test procedure (!) Is how we find a dodgy on the VAG range of cars,
Not saying it will work on Renault, as about the only thing I have done on the M9R is servicing and clutches.
( Oh and condemned an engine when he boiled it dry )
Good luck,
