The vehicle cuts out or slows down especially when going up steep hills and if I turn the vehicle off and switch it back on again the problem goes away see the image which indicate the dash lights that come on at that time
185437
any ideas how to eliminate this problem permanently much appreciated Peter
You have got a fault, and the only way you are going to find THIS fault is to have diagnostics on the car with the fault present.
The minute you switch the engine off, the fault will vanish,
Possible faults here
Fuel related ( Injector not able to hold diesel under load, so fuel rail is being emptied to fast )
Turbo waste gate is sticking ( vacuum leak, Waste gate not returning , turbo solenoid faulty )
Air related ( MAF sensor going flat line )
All these faults will put the engine in limp mode until ignition is switched off
