We have a 2003 trafic 1.9dci and it has a clutch pedal problem it goes flat to the floor, no fluid on the floor and I can't see any on the floor underneath the van, I have changed the master cylinder and it's still not working any ideas would be grateful.
I think you've already answered the question. You've changed the master cylinder so all that's left is the slave cylinder and connecting pipe. Sometimes these have a damper (small canister shaped thing) in the middle of the connecting pipe, check that's not leaking. Most likely it's a faulty slave cylinder. I've come across literally dozens of these over the years. Not sure why it particularly affects trafics and vivaros but it does unfortunately.
