I have a problem every morning when I start the engine. The engine starts up OK but will not come up to revs when I press the accelerator pedal. in fact nothing happens. The problem clears after about 10 seconds and the engine will pick up when I press down the accelerator pedal. I do not then have a problem when starting the engine during the rest of the day.
The van has been in the garage several times but still not resolved, getting quite desperate.
Any advice greatly received.
Steve
are they any warning light on ? are you getting any fault codes?
has it been to a renault garage ?
renault have a software solution for some , or needs 4 injectors.
there is an ecu reprogramming for this fault , done lots.
needs to be the correct programme though.
No warning lights come on. It has been in the Renault garage twice, plus a local garage three times. I am not sure about the fault codes.
Thanks for your response.
