1 - 8 of 8 Posts
Has anyone here replaced their own lower suspension arm (wishbone) balljoints, if so is there a walkthrough available?
Going to do these myself if I can (compotent DIYer) but could do with any tips or a photographic guide?
Many thanks
Allan
hi, did you try the search facility on this forum?
Hi there.I have changed loads of laguna lower arms and they can be a little awkward the first time.You are supposed to remove the complete subframe assembly to change them as the wishbone mounting bolts come out upwards and snag on the body. I have done them without doing this by just releasing one side at a time.I would be careful if you are doing it on a jack and not a ramp as it can be quite difficult at the best of times.
The joints are now available seperately from the wishbones,which makes the job a million times easier.:)
Just undo the pinch bolt in the bottom of the hub,knock the wishbone down and out of it's mounting hole and drill the old rivets out that hold the joint into the wishbone.You might get lucky and find that they have been changed before meaning you have to just undo the bolts holding the joint in as someone else has removed the rivets.:)
Hi Lagdti
The rivets are already out as someone appears to have done them before already.
So I should be able to undo the bolts and put the new one in? Don't have to worry about shocker or anything else do I?
Allan
All you need to is remove the pinch bolt and knock the wishbone out of the hub.:).Just be a bit carefull that you don't pull the driveshaft out of the gearbox,and that you don't hit the ABS sensor etc.Just unbolt the old joint and bolt the new one in(using new bolts if supplied).
You should be fine.:)
1 - 8 of 8 Posts
