1 - 20 of 50 Posts
Going to replace front and back brakes on my van tomorrow.
Getting pads from Euro car parts at £14.34 front and same for rear Eicher is the brand name any good?.
can any body help with a step by step guide and do I need any special tool?.
Any help would be much appreciated.
gaz672
Re: Replacing Renault trafic brakes o5
Are you just replacing the pads? If you've done pads before then you won't struggle. May need to wind in the rear piston.
Dave
Yes only replacing pads
When winding in rear pistons do I need a special tool
Thanks for help
I'm a drummer, I hit things!
Yes, you need a wind back tool, RH thread and the correct adaptor. Just turning the piston is not enough, you need some possitive pressure on it too to make it retract. I got my tool from eBay, about £30 and It pays for itself the first time you use it.
Thanks a lot going to look for tool on ebay now
Cheers
Gaz
Looks identical to mine. Very useful even on normal pistons. Gets them back nicely square.
Dave
Threaded. Winder for each side. Plain plates used for standard pistons, patterned plates for different makes.
Dave
Thanks for that info. just as i'd expected, good job i did'nt go at it with a piece of wood and a G-clamp :eek::eek: like in t'old days :d
Thanks again
Ralph
Dave
When you say winder for each side in the kit
Ones LH & ones RH threaded
I'd only need the RH would'nt i ? clockwise.
Rear single pot calipers would be easy,
front 2 pot, you have to wedge a piece of wood on 1 pot to stop it coming out while you wind other one in - correct ?
Good grief, piece of wood and a g-clamp. I remember changing the ring gear with an oven, freezer(compartment in the fridge), and a rubber mallet. Now, if you don't have computerised equipment, you can't do any work on a car.
Keith
I find most things can be accomplished using a rubber mallet :baseballbat:
- a must for every toolbox
(copper head can be used also !)
Wishes
Ralph
Spot on Ralph.
Dave
Sexy at 71 super mod..
I have the identical set and its good and I payed a great deal more for it than that..I'm sure I could have got mine to you so you could use it but to late you have bought it now..:d
On the pads in question in post 1 ..avoid they are low quality..seen many a write up on brake fade on other forums with those..
Yes, see it, I would'nt buy that sh*t, you forget i spent nearly 6 years looking for bolt on bits for my Peugeot 405 & some of those bits were one off's. I know what is good & what to steer clear of.
Cheers Phil :d
Renault Trafic - Covering May2001 to 2011 (Y to 11 reg)
Right then, Sunday morning the sun is shining, time to tackle the
front discs & pads:
You will need : Pads(4) & new guide pin bolts 4 off,
Discs (2) & 2 M8 disc retaining bolts
T40 torx head, 12mm socket, 18mm socket, torque wrench,
hide or wooden mallet
Jack, axle stands, anti-seize compound (copper grease),
syringe & glass jar.
Brake cleaner & small soft brush, eye protection & mask.
· If not fitting discs then do not follow instructions marked with a bullet
Jack up front of your van & support it on axle stands
Take cap of brake fluid reservoir
Take the road wheel off
Undo the 2 guide pin bolts (12mm socket) lift off & support the calliper
Remove the 2 brake pads
· Undo the M8 bolt holding the disc on (T40 torx)
· Undo the 2 mounting bracket bolts (18mm socket) & remove the mounting bracket
· Remove the disc by giving it a few taps on the rear face.
(wear eye protection)
Push in the pistons using a retraction tool
(pistons are not threaded on the front)
Use a piece of wood on the other piston to prevent it coming out
KEEP AN EYE ON THE FLUID if needed, draw some out with a syringe & put in a glass jar.
Clean everything using brake cleaner & a soft brush[/FONT][/SIZE]
(wear a mask & eye protection)
Now you can put it all back together: (copper grease all threads prior to assembly)
· Put some copper grease on hub face before putting new disc on
· Clean new disc faces with a suitable solvent
· Hold disc in place with new M8 bolt (21 Nm or 15 lbf ft)
· Fit mounting bracket & torque up the 2 bolts (107Nm or 79 lbf ft)
Fit new brake pads & apply a little copper grease to the back plates
Fit calliper & torque up the guide pin 2 bolts (35 Nm or 26 lbf ft)
Refit the flexible brake hose back into its bracket
Refit road wheel & check brake fluid level & refit cap on reservoir.
Repeatedly depress brake pedal till normal pressure returns.
News discs & pads need to be bedded in so no heavy braking for a few hundred miles.
N.B you may have noticed in photo below that the rubber has perished on one of the pistons, this piston was harder to wind back & will be sorted ASAP.
Pictures are taken from Offside of vehicle
Ralph - (chuffer690)
1 - 20 of 50 Posts
