Hi can anyone help I want to fit a front and rear dash cam with reverse park .. which wire do I connect to for reverse light on a 2008 Renault grand modus
Many thanks
Ignition ON, put it in Reverse and look for 12V in the rear lamp, whichever has white part for reverse.
hi
On my Megane ST the reverse wire is white, don't know if you car will be same. Perhaps you could report back when you confirm which wire it is on your car.
Al.
Discussion Starter · #5 ·
Will do when I find it … now have this come up after I changed a fuse for the reverse lights, had diagnostics done and it comes up with circuit fuse so looking for an auto electrician 🙁
192435
