2001 laguna II 1.9dci reversing lights dont work ive checked fuse and bulbs where shall i look next ( reversing light switch ) if so where is it any ideas guys it worked fine up till today
yes it is 6 speed only conector i can see on the box is at the front on the side is this the right one thi is looking from underneath
Tourerman
To get to the switch on the 6 speed box you need to remove the aircleaner and inlet ducts to access it. sits on TOP of the box. The 5 speed box has it on the side.
Hi Jabba - have you checked if there is current going to the rear lamp sockets - much easier to do before you start taking out the air filter box, etc.:)
thanx for all info mended at a cost of £19 for new part was tricky to get in but didnt remove anything
