hi just a question,
i just buyed a megane coupe 1.6 2001 but theres 1 thing wrong the revs when i start the car up the rev goes up but the drops down and stays inbetween 5 and 10 (about 6) and i bit of a miss fire any one know what that can be iv check plugs,ait fillter,i know you can do the idling but wana do that last , and have they got a cam belt or are they chain drivin
THANKS
Re: ruvs dipping droping
The engine has a timing belt - no chain I'm afraid.
The idle speed is controlled by the ECU and is not adjustable so I suspect you have a problem elsewhere. As faulty ingition coils are a common problem I suggest you start by checking this aspect first.:)
i have done that there fine
