I may be wrong here but I am under the impression that if we are talking about the same thing, you say actuator I think it;s a wast gate, that the valve should be closed allowing all exhaust gas to go through the turbo, only opening if the turbo boost gets too high, unless you have a variable vane turbo in which case I am even less sure, but as far as I know only the DCi 100's and above have them.
