Hi to everyone I'm new to the forum and need some help please.
Just bought my first renault it's a megane extreme convertible 2008.very happy with the car but it had an issue with the back window it didn't line up to the front window so there's a gap between the two window seals i looked it up on Google and found these can be adjusted so today i removed the inner back side trim to gain access to the window with no luck i couldn't find how to adjusted the window so i put all back together and thought okay garage job However since doing this the roof has now stopped working all i get is a beep and a message saying see hand book which i don't have what's happened the only thing's i disconnected was the rear speaker and the window switch all the windows work fine one at a time or all together with the centre console switch I need to get the roof open and clean and treat the rubber seals as there's a small leak on the passenger side and the boot is leaking as well. Is there a reset i can try to get the roof working again thanks Rod
