When I start my Renault Clio and I rev it there's a rumbling sound it sounds like it's in the bottom of the engine after I rev it the noise goes until I rev it higher it stops when it's warmed up. Can anyone help incase it serious
Get your local friendly mechanic to take a look A.S.A.P. You may have a serious "bottom end" problem...crankshaft bearings/thrust washer or the like...Engine noise is not too hard to diagnose, but is costly to repair...I hope this helps...
RayM...
