Any ideas of what this rumbling noise is coming from what appears to be my front wheel?
L lottie · Registered Joined Mar 31, 2007 · 2 Posts Discussion Starter • #1 • Mar 31, 2007 Any ideas of what this rumbling noise is coming from what appears to be my front wheel?
L leroy · RIP 31-12-2008 Joined Jan 6, 2006 · 5,807 Posts #2 • Mar 31, 2007 Hello there lottie and welcome to Renault Forums, this may be a wheel bearing, if you raise the car and give the wheel in question a good rock or shake if it moves a bit it could well be the bearing, I'm sure other advice will follow, Regards Leroy
chris m · Let's be carefull out there Joined Jan 10, 2006 · 19,360 Posts #3 • Mar 31, 2007 welcome to the forum. Sounds like a bearing, does the noise increase with speed? Check out the (Ahem) excellent how to in the Clio Articles (link in the side bar) it's complete with excellent photos
A A former member · Guest Joined Jan 1, 1970 · 0 Posts #4 • Mar 31, 2007 (Edited) chris m said: welcome to the forum. Sounds like a bearing, does the noise increase with speed? Check out the (Ahem) excellent how to in the Clio Articles (link in the side bar) it's complete with excellent photos Click to expand... Go on you know you want to Welcome to the forum
L lottie · Registered Joined Mar 31, 2007 · 2 Posts Discussion Starter • #5 • Mar 31, 2007 cheers thanks for the welcome....will take on board your advice
