Have you tried swapping the wheel?
It could be a tyre issue, if you swap the wheels around the noise will move with the tyre.....
Otherwise I would suspect premature bearing failure, jack the car up and spin the wheel by hand, if you hear any noises or feel play in the wheel this would confirm a problem
