Hi mate check threads on Sat nav on here ,you can buy a mag mount ariel ,just unplug the old wire from out of c.d unit (yours is mounted in glove box i presume??)access is from underneath pull down flap its velcro fitted look under and you will see small black wire in rear of unit,this is sat nav ariel just pull it out and replace it with new one ,the mag mount one comes with 5 meters of wire so you can stick it wherever you want,i ran mine back into the rear of the motta,eased doewn the roof liner and stuck it between the roof and the liner just behind the shark fin,avaliable from www.t-era.co.uk price around £13..smb connector type,
