M
Used the guidance mode recently and noticed there were no verbal instructions when approaching roundabouts, junctions etc. anybody got any ideas as to what the fault is?
Hi there, check the most obvious things first - that the volume hasn't been cut off by pressing the (C) button, the display would show the loudspeaker symbol with a line through it if this was the case. Or that someone hasn't been messing around with the volume, try pressing the (+) key a few times.
Failing that, it may be a software glitch, I would try switching the system on & off a few times to try a gentle reboot or re-insert the CD.
Hope that helps.
Paul:)
M
Thanks for the info, seems that someone had been messing with the vol pressed the + and now she's talking to me.
