Hi, Renault Meganevwith sat nav, is there any way to program the sat nav so that the radio mutes when the voice is giving out directions,?
In normal mode should be like that. In MediaNav's work like that, but in other sat nav can be a little different depending by how the builder eas thinking. Important is to hear clear the voice of navi.
Trimis de pe al meu SM-A705FN folosind Tapatalk
Captur 2017 1.5DCi EDC
If it's a Renault satnav (e.g. medianav) then it should mute the radio when talking. Question I would be asking is why is it not working..
I didn't understood well which unit type is.
Not all stops radio or music while voice for navi play, but it is lower for sure the volume.
Perhaps over there is a bug in software and need an upgrade.
  • Like
Reactions: twodogs
I had a similar issue when I first got my Meg. Volume of the voice was to quiet.
if you press the repeat button and increase the volume using the stalk as it speaks, it raises
the sat nav volume but not the radio.
You should now hear the voice over the music.
Al
