Hi - I have a starting problem. After the engine has been stopped for sometime, eg overnight, air has got into the fuel system.
So the engine won't start until the fuel pump has been re-primed. As you are instucted to do, in the haynes manual, after a feul fiter change. Bubbles can be seen in the plastic fuel pipes.
It has the one piece fuel filter with the five snap connectors on the top. I replaced the fuel filter to see if this cured the problem - it didn't!
Is this a known problem? Has anybodyelse had this problem? Any ideas how to find where the air leak is? No sign of leaking fuel!
Steve
Steve
