Can anyone help me? :(
My scenic has started to produce a whistling noise when accelerating. The pitch of the whistling increases with the revs. It could be my imagination, but it seems to have slightly reduced power as well.
I had a similar problem with a laguna which turned out to be a split intercooler, but I'm hoping this isn't as bad. Any ideas?
Cheers.
Welcome to the forum.:)
It could very well be a split intercooler or turbo pipe......it could also be the dreaded turbo failure problem rearing it's ugly head again.:(
I'd get it checked asap.
:( Starting to look bad then!
Forgot to mention that it's getting through a lot of Oil as well, plus occasional black smoke from the exhaust.
I didn't know if it could be the EGR valve that seems to be mentioned alot on the forums?
Sounds very much like the turbo on its way out.. Get it checked before it is too late!!
