Hello, I have a strange fault with my 2000 scenic 1.4. The Fog lamp indicator lamp on the dash illuminates when the brakes are pressed and when the indicators are on. The lamp does not light up as bright as when the fog lamp is actually on, it's probably about half as bright.
Any ideas?
Chances are it a poor connection on the connector/s to the rear lights.
It's normally an earth problem.
Unplug the connectors and check for corrosion in the wiring plug and on the bulb holder.
Will check that Dave, the fault appears with both indicators so i think it may be a problem on both sides.
