Question, are all scenic 1 rear light units the same? My sister has a 51 plate and has broken the drivers rear light unit and i'm just wondering if someone can confirm if all the scenic 1's are the same or did they change at some point?
Thanks in advance. :)
Having just replaced the unit on my wifes car, I found that all scenic 1 models running 99-03 are the same.
For a quick and very inexpensive replacement have a look on Ebay. Try scenic tail light as I found one last week for £4.00.
And it is very easy to fit yourself. Just undo the 2 nuts inside the bulb box behind the unit.
Hope this helps.
