21 - 40 of 97 Posts
cannot look at the moment some dopey sod is uploading off this part ,
He seems to be having Problems LOL
Why have you not looked it up..
Its you
Click on the disc, scroll down to properties an UNBLOCK , Press apply then try it
( Did I not tell you this LOL)
Did send you a new torrent , and asked if you had downloaded, but got no reply so cooked diner
Discussion Starter #26
Its you
Click on the disc, scroll down to properties an UNBLOCK , In Security I do not see anything Blocked to unblock.
I did not get another Torrent from you, or a message, can you send it again.
Discussion Starter #27 (Edited)
Hi all.
I found this wire that comes from the harness, that runs from the motor, found it loose under the battery tray. Would this connect under the tray, the wire is long enough to go to the other side on the battery, negative side, but not long enough to connect to negative terminal clip, does anyone know where it attaches to.
Please see attached pics
I have traced the black wire to the fuel filter I think. See pics attached
Ian not a clue, what colour is this wire ..
Have you checked its not broken inside the loom the other side ..
It could mean you stripping the loom back to see where it goes
You could try using your meter on ohms
Make sure battery is off at this point
NOT disconnected, off and out the way ..
Get at the main fuses under the Under Bonnet fuse box and see if it gives a circuit to one of them
If yes, might be able to help
Not come across a Disc for Scenics
( Got Megane wiring discs but all discs I have for Scenic, nothing inside or format not known )
Russians LOL
Discussion Starter #31
Hi Stuart.
The wire is black, I have been busy with Slave cylinder, what a job to take that out, my first gearbox removal.
All sorted and back in, took longer that I expected with all the rain in Cape Town.
I will be looking at that black wire today, to see if I can find were it must go. I hope that thats the problem
Discussion Starter #32
Hi Good afternoon.
So I got to work on car again, I took all the looms apart and checked all wiring, could not find were the black wire may have come from, so I attached it to the body of car, as it looks like a earth wire.
Still no start. I looked around again and noticed this purple wire hanging loose, from the Alternater plug, its not attached to the plug, and can see that it had a break in it and has been rejoined, with bear connection, but not connected to alternator,
WILL THIS CAUSE A NONE START?
Struggle on the site now to play with pictures Ian ..
Whats fitted down that area,,
WE need a picture showing all the Engine really
Discussion Starter #34
Do not worry about the pic then Stuart, its a purple wire that goes to the Alternator, it broken off the plug that connects to the alternator, Can anyone help? Can this cause the car not to start?
No that wont stop the car from running
Whats Diagnostics showing?
You have crank signal, you have cam signal, you have fuel?
Does it sound as though it has compression?
Discussion Starter #36 (Edited)
Hi Good morning I hope you well today.
You have crank signal, No but I get engine speed, No crank sensor you have cam signal, No, you have fuel? Yes On one bar and I topped it up today with 5 liters, still one bar.
Diagnostics
Engine
DF056 - Mass air flow sensor
- Offset at min limit
- Intermittent
DF025 - Pre-postheating unit diagnostic line
- No ststus
- Permanent
Tyre pressure monitoring
DF016 - At least 2 identical wheel valve codes
DF017 - At least 2 identical wheel valve codes
DF018 - Prog 4 codes in wheel set not performed
DF019 - Prog 4 codes in wheel set not performed
Electronic PAS (Power steering)
DF038 - Angle sensor
- Abnormal voltage
- Intermittent
DF033 - Multiplexed network
- signal missing or faulty
- Intermittent
Engine compartment
DF034 - Alternator
- Incoherence
- Permanent
Real Time Data
Fuel flow correction cylinder number 1 - 0.00mg /cp
Fuel flow correction cylinder number 2 - 0.00mg /cp
Fuel flow correction cylinder number 3 - 0.00mg /cp
Fuel flow correction cylinder number 4 - 0.00mg /cp
EGR system fault - 16
Air flow reference for EGR - 627.9 MG/CP
Rail pressure - 5 Bar
Engine - Stalled
Synchronization - Not done
Engine immobiliser - Inactive
Turbocharging s.v ocr setting - 5.1%
Turbo solenoid valve position correction -5.0%
How would I hear if it has compression?
These are the reading that I got today
Thanks Ian
So you have a crank signal, if RPM is showing
Can you check for a Cam signal..
should be able to see this with Delphi..
Dont mean fuel in the tank, Fuel pressure, is any showing on cranking? Can you post Oval Ian, will have a couple of hours tomorrow afternoon, and will switch tother laptop on and have a look..
Your Pre post heating fault needs sorting here,
Would see why thats not playing ball, as on your year that is part of starting and pretty sure without it working you wont have any joy
Discussion Starter #39
I have checked in the area were you usually find Crank sensor but nothing there, I will have a look for Cam sensor reading, does it come under something else as the last time you asked I could not find it on the Delphi System.
Please Oval sticker attached
21 - 40 of 97 Posts
