i
Hi good morning.
DF041
Cylinder 2 Injector Circuit
Open circuit
Intermittent
DF 056
Master air flow sensor
Short circuit to ground or open circuit
Intermittent
DF056
Mass air flow sensor
Offset at min limit
Intermittent
DF025
Pre- postheating unit diagnostic line
No status
Permanent
When I got it started yesterday. I used quick start. When conected intercoolant pipe back on car died. Done it a few timesso its a wiring fault then, you have proved its not injector why are you going on a compression test
[*]It say on Dialogys to check connector c is that the bottom connector on ecu or the top.
[*]Also say I must run test 1 Injector Test ? Not sure what that is. Thanks
[/LIST]That's what Serser69 suggested.so its a wiring fault then, you have proved its not injector why are you going on a compression test before sorting wiring out
Ok can you please help. Not sure of following
Grey 32 track connector C. Is that top or bottom . What is track G4 ?
Thanks guys for your help. I will check wiring then sort out the compression test. On a petrol you do a wet and dry is that the same on Desielyou are right, but "vice versa"
Ok can you please help. Not sure of followingThanks guys for your help. I will check wiring then sort out the compression test. On a petrol you do a wet and dry is that the same on Desiel
Hi all again.Ok can you please help. Not sure of following
Grey 32 track connector C. Is that top or bottom plug on ecu ? What is track G4 ?
If I got water some how into the oil chambers well taking the head off. I did disconect the water thermostats housing to let water out before taking head off to check valves. I did not take the oil out. If a small amount of water got into oil. Could this cause the white smoke. And the loud noise.The oil on dipstick is not mayonnaise ish. No white mayonnaise on oil cap. Its synthetic oil. ?Hi all again.
Stuart I tested the continuity on the grey and cream wire on plug c and plug to injector all good. I get continuity. I started it again still loud noise. White smoke out exhaust and pvc valve. I had to start with quick start every time. When running and I put intercooling air pipe back on motor dies. If I leave off monitor runs for about 3 min idle and dies. Smoke also coming through inter cooling pipe. I am sure from breather pipe. So looks like I am going to have to do compression test. How do I do the compression test please help
There is a product on the market in spear shop that claims to seal steam seal. I think it also seals piston rings. How good is that do you know?
I also did not change the head gasket. It looked newIf I got water some how into the oil chambers well taking the head off. I did disconect the water thermostats housing to let water out before taking head off to check valves. I did not take the oil out. If a small amount of water got into oil. Could this cause the white smoke. And the loud noise.The oil on dipstick is not mayonnaise ish. No white mayonnaise on oil cap. Its synthetic oil. ?
Please help ?
Thanks Stuwart.struggling to work out how an electrical fault will be from inside the engine..
List the fault codes as they appear ,,
Lets see if we can work out whats possible/probable cause before you strip down half your engine..
Pull the breather pipe off the turbo/air flow , start the engine and read/diagnose ..
P.S. What are you using Ian, Wurth, Or Deplhi?
When I had the head off and moved valves to closed position . 1 and 4. The slit in the camshaft is at 12 o clock. When I connected the pulley back on. Pin in slit of camshaft. The sprocket timing mark lined up with Mark on casing. .when cylinder 1 and 4 valves were closed, did the timing mark on the sprocket line up correctly to the hole in the Casing
You are checking that the hole in the casing is TDC for cam?
