Can anyone help,i have just had new rear brake discs fitted. Since then a warning signal followed by a message (brake problem) and various warning lights appear when driving at any speed it varies.:confused:
If the fault was not present before the work was carried out on the car then return it to wherever you had the work undertaken and ask them to correct the fault. I'd expect them to repair it free of charge.
Obviously only drive the car if it's safe to do so. If not get them to uplift it.
