1 - 9 of 9 Posts
Hi.
Can you buy a replacement power cable for a sliding centre console?
Just I bought one for my scenic, but the connector has been snipped off of the cable. I noticed that it connects to a green connector on the inside.
I can try and get some photos if needed to verify what I am talking about.
Thanks.
I think a scrappies would be your best bet, then you take if off yourself carefully leaving both connectors in place.
Does it have to be correct connector, can you not make a wire/harness up and fit with male connectors..
Hi.
My record with car electrics is not the best, and I don't know any auto electricians that could knock one up for me.
Scrappies. I might know of one that might have one, but I will have to rack my brain to remember who they are. Got a replacement bumper from them a couple of years ago.
if it is not a seperate lead and is part of the loom (as @ours2012 said) then you are going to have to do some wiring or get someone confident ( and competant) enough to wire it up for you
1 - 9 of 9 Posts
