i washed my screen earlier and as the wipers started clearing the screen the wipers tangled up and now the drivers 1 will not move but the passenger 1 is fine is this the dreaded scenic wiper problem motor seems fine help anyone:steam::steam::steam::steam::steam::steam:
O
Is the wiper arm still in place?
Does anything on the drivers side move at all?
Undo a couple of nuts, lift the plastic cowl off and look inside. You'll see the wiper assembly and will soon see what has happened.
I had the same problem after I had the cambelt changed, the garage hadn't tightened the retaining nut up but I'm guessing you've probably checked that?
