Just a quick question, will a 22DC278/62H fit in a "Y" reg 2201 Scenic 1.6 RT, will it be a straight fit?
Further question, will a 22DC279/62 fit, don't know if i am posting properly as this forum is new to me, sorry if i have not got it right.
I'm not familiar with the numbers you've quoted,but as long as the CD player is genuine Renault and from the same era,it should fit straight in.
Is there any writing on the front of the set at all?.I suspect no one has answered your question as the radios are only known by their name and not the part or serial numbers.
The numbers quoted are from Phillips and this format of numbers is used frequently in posts as by Glenda and Mickdoc
Presumably you require the curved front model 279/62 as with the other model you would require a fascia adaptor.
As long as the plugs are the same then they should operate satisfactorily.
Both of these units have the mini ISO sockets for the remote(yellow) and the Cd changer(Blue)
