every time i stop at junction,lights or roundabout car cuts out has no idle any ideas drives fine when stared
Hello,
What engine has your scenic got? Is the fault worse when the engine is hot or cold? Are any warning lights coming on and staying on?
Harry.
its a 1.6 vvt and the day after idle started i got the check emissions light came on
when first start on morning get idle for few mins then most the day no idle cheers bud
Hello is the engine missfiring, do you ever get a rattle like noise on start up. If its idling poorly when the engine is cold then the temp sensor could be faulty. Also the throttle body being gummed up would cause idling problems.
Harry.
car does rattle for second on start up but idle ok cold just after it gets a little warm then starts cutting out
