I have been reading through several threads on what seems a common problem on the scenics of the heater resistor needing replacement.
My problem is heater blows only on #4. Renault Grand Scenic 2007 2.0l auto.
I watched a few videos and decided, after checking the 40A fuse was ok to buy a new resistor to crimp on and do the job today.
but variations are the problem. Its not quite what I hoped, in one the video the guy removed the dash surround and LED panel and hey presto there was the resistor pack which he duly replaced.
www.renaultforums.co.uk
In another video (I found today) someone remove the gear lever housing and screws in the glovebox in order to access it . His resistor pack is more than a £3 resistor to crimp on as well. BUT his was LHD, they (videos) all are. Mine is RHD.
So first Q, is the resistor housing on LH or RHS.
My surround is out, LED panel removed but no resistor pack was there so that's fair enough, wrong video, £3 nothing too painful but before I order the Pn: 7701207718 I would like to ask am I going down the right path or do I need to look harder for the resistor pack wioth the facia panel out ?. I can dismantle tomorrow and wait few days for replacement to arrive if that is actually my problem.
many thanks for any guidance
Kevin
Renault Scenic II - Access the resistor pack in 5 mins.
I don't know if this has been posted before. I just managed to access the resistor pack in 5 mins, maybe less. Haynes reckon the dash top fascia needs to be removed, massive job. I avoided this. I simply removed the two digital dash surrounds, then to the right of the digital display is quite a...
Kevin
