Relay C = rear wind screen relay
Relay D = Horn
That fuse is to energise engine running relay
so that could be the issue, not saying it is
But no-one has ever mentioned issues with this fuse box inside the car ,
( You could be the first )
Change the fuse and see how you go on
If no joy attack starter motor
Pull small wire off starter, get a piece of wire that will reach battery area
Connect to the small/thin wire your piece of wire, the other end of your extended wire connect multimeter red probe to this (Set multimeter on volts) extended wire, other black probe to the battery negative
Set multimeter in a position you can see it from inside the car
Press start button, screen should show around battery voltage show on the multimeter
Relay D = Horn
