I have a 2010 grand scenic and today when connecting my phone to the bluetooth the radio interface froze... when I switched the radio off it shut down but the satnav screen stayed active. Now the radio wont turn back on and so the satnav is stuck on
What should I do?
Have you tried removing the relevant fuses - leave it for 5 minutes - then re-insert the fuses - it may reset itself.
thanks, just read somewhere else that someone with the same issue did this and it worked... but...
just looked in the fuse box and fuse 16 which the manual quotes is for the radio is just an empty space... all others are present its just that fuse thats not there
