hi i have an 02 plate 1.9dci . did a 300 mile trip home. went to move later and refused to start. engine turns but does not fire at all. does not even try. fuel is coming from pump. any ideas where i start to look ? thanks.
ok what do i do ? how do i check it?
we did notice the interior light went on and door lock/ unlock a couple of times when driving home. we have car set up so it locks when you drive off.
just tried both keys. alarm flashing light on dash goes out when you unlock car. and goes on when you turn key for 2 seconds and then goes out. Haynes manual says this means immobilser working ok. ?????
i have opened the fob and obtained the emergency code. cant work out how to enter it. i put key in and turn but do not get a rapid flashing light that slows when i press central locking. just the usual flashing light. what i am doing wrong ?????
