Hi Everyone,
This is my first post here and I need some desperate help from yous..
I am from sydney, Australia and I own a Renault Scenic 2004 (manual) model. Had no problems with the car until recently (probably over the past 3 months) and now I am starting to hate this car...This is what happened:
The problem started 3 months ago. When I try to start the car in the morning, it started to take unusually longer to get it started. The engine simply rolls over and I need to keep trying 2-3 times at first before the engine fires up. First I thought its not so bad thinking i can deal with it and hopefully it will work fine by itself..But it didnt work. THe problem got worse and it started to take a lot longer to start the car eventually. The weird thing is, once the car starts, it works fine the rest of the day unless until the car was sitting idle for over 12 hours or so, then the same prob again.
I had it checked with NRMA service and they recommended to take it to an auto-electrician. He said that the fuses are fine but for some reason there is no spark. He even said sometimes it can be a prob with the coded key. In the mean time the car battery went fully dead since I was trying to start the car for long time and it completely wont start..only roll over. This is when I had to tow the car to an auto electrician.
As the mechanic was checking the car, apparently the car started to work fine all of a sudden again! He was surprised himself and not sure what the problem was. He kept the car in his garage for 2 days to check if it starts again, and guess what...it was working fine and he didn't even do anything!!
After numerous attempts, he said that he thinks the crank sensor could be playing up so it needs to be changed. So i had to spend over $200 for a crank sensor. They are not cheap in aus! While he was fixing this, in the mean time the battery got fully drained. He said the battery needs to changed as well now since it wasnt recharging due to its age. So, I spent another $300 for the stupid battery. Now it has a new crank sensor and new battery and an expense of over $700 already altogether including labour, towing and everything! So I was hoping the problem is fixed.
I got the car back 3 weeks ago. The first couple of days I noticed that the problem was still there. This time however the car started in the second try itself though but it still did not start straight away. Slowly after a few days, the delay became longer. Last week, to start my car, i had to try 3-4 times with a duration of 5-6 seconds each time. It simply keeps turning over! only after a many tries it starts!!
The weird thing happened this week. From monday to wed, the car all of a sudden started to work fine. It started straight away when I tried. I was really surprised to see it working again but I had done nothing! I have no idea with the mechanical part of the car and was surprised to see it work on its own as if there was no problem. I was happy it did though! But my happiness was short lived. The problem started again today. Turn over....no starting...I am really getting sick of this.
My biggest worry is, I have no idea on whats wrong with the car. Even my mechanic has no idea...I cant keep changing the parts based on my mechanic's guesses since it could end up costing me big time if I keep changing parts based on his guess and if it still doesnt work!!!
I have been searching the internet for hours on this and I noticed that a lot of people are having the same problem. But it confuses me cuz different people are saying different things...one is saying it it tdc sensor, the other is saying it is fues injection relay, one says it is battery etc..etc...Which of these are right?? If this problem is so common, what is the solution?
Please help....I would really appreciate it...
Cheers..
Cheers..
