I have a 1999/2000 megane scenic 1.6 rxe......most times when the ignition key is turned it wont start, it turns over happily, and maybe after about 5 minutes it will eventually start. yet sometimes it starts on the first turn. someone has suggested the crankshaft sensor but i have no real idea? if so can it be cleaned or does it need replacing?
Paul
Thanks Chris.......is there anything else this problem can be attributed to? lastly the only other problem i have is the external temp reading, it is reading completely abstract figures, ie -34 when its actually +16 etc any ideas on this either.......all advice /help very much appreciated
Hi Paul - looks like the external temp probe is not working correctly or the cables to it are damaged - have a search through the forum for more info.,:)
