My Scenic has developed an intermitant fault which is getting more regular in that on start-up a "check injection" service message is displayed and in limp mode. if turned off and re-started then message does not appear and drives fine. this doesn't happen everytime. also occasionally it wont idle cold until revved for a bit and on odd occasion won't catch at all.
after trawling forums i concluded TDC sensor fault, so took sensor off and cleaned it. problem fixed for 2 days then re-appeared. removed plug connector and cleaned with wd40 which fixed it for another couple of days. noticed new versions available with blue plugs so instead of buying renault part i bought a fuel parts one new from e-bay.
had a hell of a job connecting wires together as so short when plug cut off but just about mangaged it, fitted new sensor and problem gone... for a week! now same problem back again!!!:crazy:
if i disconnect and re-connect plug its better for a couple of starts but not great.
could the new sensor be duff in the same way as old sensor or am i looking at the wrong area?
any help would be much appreciated!
