I have searched the forums and not come across my bizarre problem anywhere.
The Scenic is a 53 plate 1.5dci with 82000 miles on the clock. I have used the advice on these forums to fix my windscreen wipers and get the clock fix from Renault for the £100.... I am therefore already endebted to these forums!!
Ordinarily, the car starts, idles and runs wonderfully. It is still pulling properly and is smooth and willing to rev etc. HOWEVER, occasionally it hiccups and carries on driving normally. It feels like a bit of muck in one of the injectors which clears itself and then all is good again.
Sadly, about once every 20 miles it hiccups and the instrument panel asks me to select neutral before coming to a halt. The engine remains running but the car will not allow it to continue. If you pull to the side of the road, take the key out, stop the engine and then restart it will start as normal and continue as normal.
My initial thoughts are that one, or more, of the injectors is on its way out and causing the "hiccup". However, does the Scenic have a management system which will cut power if it thinks an injector problem could be dangerous??
In an attempt to clean the injectors I have used one of the fuel additives but this seems like a complete waste of £8. It doesn't seem to make things worse or better!!
Any thoughts would be really appreciated before I need to take it to be diagnosed by the Renault dealers and there licence to rape and pillage!!
