Well I fixed my front passenger window after a CRUNCH sounded inside the door last summer - finally got the parts off ebay and fitted perfectly.
However, this problem is my driver side rear door. The window never worked correctly - the Renault garage had it in loads of times, the best fix they could manage was to have that one switch that worked back to front on the driver panel but fine on the rear door.
Anyway a year or 2 ago it stopped working totally - and thats fine, I can cope with that. BUT I cannot accept an open window, a couple of months ago I started the car and the window wend down an inch. Nothing worked to make it go up or down then or since.
Ive opened the door up - dry as a bone. I've taken the panel and side off, to access the electric winder - but it wont budge, electrics not working at all. SO ive unplugged it and I have the unit there with its 6 pins (2 middle are wider).
My question is this - Does anyone have a pinout diagram? what voltage do i need to plug in to it just to make the window go up, then I can leave it unplugged.
The details on the electric board cover part that i can see is/are:
TEMIC 0675 C9
4407 26 F
HW CS SW 1.7
PD 20.01.04
Any help appreciated. Gaffer tape only lasts so long...
TEMIC 0675 C9
4407 26 F
HW CS SW 1.7
PD 20.01.04
