I wonder if someone could possibly help me out.
For the last couple of days my stop light and oil pressure message has appeared when the engine was cold. After a few seconds it would go out. The oil was a little low even though the computer says its fine.
Anyway this morning I drove around the road and suddenly there is now a noise coming from the engine when you rev it up which sounds like maybe metal rubbing together. When the car is idleing it is totally fine. Again the oil pressure message had turned itself off.
I took it straight home and I am now scared to drive or start it.
I was kind of thinking that maybe it was the oil pump but thats probably wishful thinking and its likely to be something far more expensive knowing my luck.
Any help is most appreciated.
