Hi all. Anyone have problems where the car alarm goes off after a few minutes you locked the doors? Happened to me when we were still in UK but Renault garage said I need a new alarm which I find to be a bit silly. I think I read somewhere that its an issue with the latch on the boot. Anyone had similar experience? Thanks.
Hi. Sometimes the bonnet switch doesn't get pressed down fully.
Lock the car and listen for a continuous beep from the passenger side rear of the car.
If you can hear it, press down on the front of the bonnet just above the Renault badge. If the sound stops then you've found the problem.
Glue a piece of rubber to the bonnet to press the switch down properly
Sent from my HTC Desire using Tapatalk
