This one seems to be beyond my local dealer.
We have a 2008 Scenic II 1.6 Dynamique Auto. In January the dealer changed a "solenoid" in the gearbox. After a couple of months the car started with an intermittent fault where the throttle occasionally "dies" for a few seconds when the car changes gear. This is always when pulling away, say out of a junction. It doesn't happen when setting off from rest. It only seems to happen when accelerating lightly. The throttle just dies for about 3 seconds. Flooring the accelerator during this time does nothing. After the 3 seconds, the car pulls away as normal and the fault may then not occur for a few hours or even days.
Its a bit hairy when it happens when you're pulling onto a busy roundabout!
Does anyone have any suggestions? My dealer is clueless!
Discussion Starter #2
I've seen elsewhere on this forum that people have had similar problems when they have had "sticking" brake lights. I'll try to look into that possibility....
The happy ending!
OK. I investigated the sticking brake lights by following the wife while she was driving and watching her brake lights, while we were both on our phones (hands-free, of course!). She shouted out when the engine died and I looked at the lights. The was no sign of the brake lights coming on.
Still bewildered I left it for a while and the problem got steadily worse.
Eventually I took it to my local Renault specialist, Reno-Tech of Llandudno Junction. He took it for a drive with his computer still attached and whilst no faults appeared there was an inconsistency - the brake pedal was seemingly being pressed occasionally whilst the accelerator was down.
I told him about the posts here and he told me that the brake switch has two circuits so I wouldn't necessarily see the brake lights come on.
In a nutshell, the switch was changed and the problem is sorted. Seemingly the gearbox was affected too as the changes are now noticeably crisper.
I hope this helps someone else one day - like my local Renault main dealer!
