Hi does anyone know what typeface/font the uppercase SCENIC badge is on the rear of the vehicle. The one I have just brought has not got one or even any markings where it may have been. I dont need a original as I have a vinyl cutting machine to produce a sticky version. Any help much appreciated. Also can someone let me know where to find in the forum about heaters etc. I have found out about looms resistors etc but my dial where tou select where you want it to come from wont turn to just window? Thanks once again
O
If you are going to print the whole word, it wouldn't matter if you get the typeface right would it?
Scroll through the microsoft word font options, you will find one that is very similar.
:iagree:
Trust me I have about 5000 typefaces as I am a graphic designer. Just thought of a shortcut instead of trolling through the lot cheers:eek:
