Hi got a 52 plate scenic 1.6 manual had both deiveshafts changed and still get a wering noise which is getting louder anyone help.
Hi if you jack the front up and holding the wheel at the bottom and at the top then push and pull the wheel if you get movement its the wheel bearing but it could be that the hub nut on the end of the drive shaft may be lose but unlikely hope this helps
