I bought a scenic from a private owner, it's a 1.4 16valve, the radio works but after 20 mins to an hour it makes a loud beep then 10 secs later it turns itself off.
You have to keep turning it back on, does anyone why this happens?
On some radios if the ignition is off and you turn on the radio it turns off after a time to save the battery, if yours is not getting the ignition feed it may be going into this mode, I would look in the fuse box for a fuse for the radio and check to see if its ok.
Sorry I don't have a clue as to were the correct fuse is on your car.
think I have that sorted now, although the radio was working the fuse had gone. replaced it and the whole radio screen came back on.
check the fuses as above mantioned
