I have a Scenic 2001 automatic and want to replace the TDC sensor.
Because the wire loom has changed shape I need to cut the original wires and attach to the new ones.
The problem is the new sensor wire loom has wires which are pink and yellow, and the original TDC sensor wires are brown and green.
Do I connect pink to brown or pink to green?
Or does it not matter?
